Determined the location for the Dynon SV-ADAHRS-200 mounting location. Chose a location on the right side of the fuselage just behind the bottom access opening. The mount will be about 2/3rds up the fuselage side to be above the static port in accordance with the Dynon ADAHRS-200 installation instructions. Began design and fabrication of the mount shelf.
Mounted the MGL VT 10 comm transceiver in the instrument panel cutout. Checked length of the cables to connect to the pilot and passenger headphones and microphone. Found that the cables were 4 feet too short. Ordered more of the shielded cable to lengthen the headphone & mic cables.
