Riveted the glove box door hinge to the instrument panel. Took a couple of pictures of the insturment panel and CF overlay before glueing them together. Cleaned both surfaces and prepared a flat place to rest the overaly and panel on while the adhesive is curing. Selected Durabond (3M) urethane small panel adhesive to use to bond the CF overaly to the aluminum instrument panel. Checked fit one last time before bonding. Applied the adhesive and put the two pieces together on the flat surface. Held the panel down to the overlay with weights while it cures.
