Bought PPG 2042 clear coat for the CF instrument panel overlay. Sanded the lacquer on the CF panel with 320 grit paper to smooth it. Applied three coats of PPG 2042 clear coat.
Aligned fuse block sub panel to the instrement panel where it needs to go. Lined up the hinge. Drilled rivet holes in the hinge and fuse block sub panel flange. Riveted the hinge to the sub panel.
