Worked on instrument panel design to finalize switch and control placement using Solidworks. Removed rivets holding the instrument panel to the fuselage. Worked on the arrangement of the fuse sub panel that will be hinged to the lower edge of the main panel on the passenger side. I don't think the three fuse blocks I have will fit. Ordered three more Hella brand 6 circuit fuse blocks from Summit Racing. Those should fit better.
