Brief Description: Wheel fairing brake cover & brake line
Sanded the filler on the brake cover. Added more filler and sanded that. Applied two coats of primer. Fastened the brake line to the right gear leg with Permatex Ultra Black #82180 adhesive. Installed the right lower fairing so I could trim it to clear the brake line. Test fit the right gear leg fairing to check how it will fit with the lower wing fairing. Both the gear leg fairing and the lower wing fairing will need to be trimmed for fit.
