Worked on the seats. Cut the seat back supports to 17" width. Cut the top section of the seat foam off even with the bottom of the seat back. Tried different size and density of foam for a lumbar support for the pilot seat. Determined that a support 7.5" wide made from pink foam felt the best as a lumbar support. Attached the lumbar support foam to the seat back foam with 3M 8090 adhesive. Glued the blue and pink foam together for the right booster seat. Trimmed foam as necessary. Shaped the foam for the booster seat spacer to give it a better shape.
