Met with upholster at the shop and discussed him covering the seat cushionsnand what I need to do to prepare the foam cushions before covering.
Devised a system for roll over protection. Evaluated several configurations. Decided a hoop type roll bar located at the rear of the cabin next to where the existing aluminum tube ends are fastened. The roll over bar will be made from 4130 0.75" dia x 0.065 " tube. Fabricated a "test" roll bar from PVC water pipe to approximate the shape of the steel tube bar. After getting the shape correct, I transferred the shape to a piece of 1" thick styrofoam. This template will serve as a guide to form the steel tube.
