Stiffened step mounting support area for right side (modified) step. Added Z stiffener across lower fuselage skin between step mounting area on both sides. Added a triangle shaped brace between vertical L angle and the added Z angle on the fuselage bottom. Added 0.025" L angle doubler to vertical L angle the step side plate is riveted to.
