Fabricated the arm rest cover. Installed four Z angles across the cover for added stiffness. Riveted and epoxied the Z angles to the cover. The arm rest cover is used as a support to lift yourself out of the seat so it can't bend or cave in on top. Clecoed the cover to the side support and tested using it to get in and out of the seat.
