Re-worked fuel line routing from fuel tank outlet to the area of the pass through hole in the side of the fuselage. Drilled 7/8" hole in nose rib #1 for grommet for fuel ine. Hole is in alignment with the pass through hole in the fuselage side.
Grounded fuel level sender ground wire to front rib #2. Put the right wing on the work table to begin the upgrade on it. Cleaned the inside of the left wing in preparation of replacing the top skin.
