Brief Description: Aileron bellcrank reinforcement, wing skin L angle
Finished aileron bellcrank mount reinforcement and attaching L angles to next rib and skin. Holes drilled and de-burred for top skin. Layed out where L angle span wise reinforcment pieces will go on the top and bottom skins and hoe they will fasten to the ribs. Made a tool to "jog" the L angles where they go under the edge of a rib flange so the top stays flat and even with the skin.
