Brief Description: Took Corvair camshaft to Oregon Cam Grinders.
The used stock cam probably isn't suitable to grind to the specs I want. The lobe centers on the stock cam is too far apart and not enough "meat" on the cams to move the lobe centers closer. I called Corvair Underground to see if they had, or could get, a blank cam. They may be able to get one and will find out tomorrow.
