JOHN'S WEB SITE
Helicycle
Rotor tach sender
Fabricated bracket for rotor tach sender. It shares the same bolts used to secure the slider bracket. Attached magnetic collar to the main rotor drive shaft. Will need to fine tune the clearance between these, later.
Rotor tach sender
F1 Rocket Evo Home
Helicycle Home
1065
Cabin Doors
Check-out and Airwor
Governor & RFI
Main Transmission
Rotor Blade
Swashplate
Swashplate
Tail Rotor
Trim Fins
Turbine engine
25
83
