Bills Web Site
LNC4
Wiring
Bundled and combed wiring bundles under main gear box.
Connected wires to AOA flap bias microswitch.
Installed and connected ELT antenna.
Riveted autopilot pitch servo push rod to elevator push rod.
Tightened all check nuts on elevator push rods.
Torqued elevator rod end bearings at idler arm.
Torqued idler arm pivot bolt.
S6-S Home
LNC2 Home
LNC4 Home
6961
Aircraft Kit
Assembly
Doors
364
526
374
Flight controls
Flight controls
Fuel
697
1545
Hardware
Hydraulics
Instrument Panel
25
241
Insturment Panel
Misc.
758
Panel
Paperwork
Weight & Balance
1136
