Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Deems Davis
  Anthem, AZ - USA
Aircraft:
  RV-10
Total Build Hours:
  3157
Web Site:
  http://www.mykitlog.com/DeemsDavis/
Date:  04-11-2009
Number of Hours:  2.50
Short Description:  Sec Final-51
It rained all last night and early today, probably the last rain we'll see until the monsoons this summer. Parker and I headed off to the airport today to glue in the door seals. I've tried 3 diferent automotive types of weatherstip / seal glue, and none of them worked worth a @#$!. I finally settled on the idea of ProSeal. that stuff sticks to ANYTHING , and it has the benefit of being able to be removed it I want to change/replace the door seal. I mixed up a couple of ozs. and put it into a plastic baggie. I cut a very small portion off of the corner of the bag, So that when squeezed it emits a ribbon about 3/32" wide. I rough cut a section of new door seal material and then appplied 1/2" ribbons every 1/2" along the edge of the cabin cover so that it would contact the U channel in the door seal. I did this in 3 sections: Top and front sides, bottom and 1/2 of back, and remainder of back and top. by using only the narrow bead, I was able to avoid getting glue on the exterior, there was a couple of places where it seeped out, but some solvent cleaned that up. I used a rubber mallet to set the seals firmily in place, and the closed each door to hold the seal in place while it cures over the weekend. It's a bugger to get the doors closed with the new seal material. Hopefully ti will compress a bit with the doors being closed for the weekend. Don't have any pcs of the process, as the camera batt was down, but got these pics as we prepared to leave.
All buttoned up for door seals to cure
Cowliing and Plenum installed for 1st time since paint
Just waiting for some fuel and a green light
 Recent Builder Activity
Builder Project Date Hours
Brad Kunkel
Zodiac CH 601 XLB
06-08
1111
Keith Borgstrom
Sonex
06-05
527
Jack Clark
RV-14A
06-04
1464
Neil Rosoff
EX-3
06-01
1167
Michael Freiherr von Maltzahn
RV-12is
05-29
513
Darrel Watson
H-5
05-25
930
Mark Jackson
RV-8
05-17
1674
Stuart Hutchison
F1 Rocket Sport Wing VH-FLY
05-16
4236
Mark Johnson
RV-10
05-09
753
Peter McBain
RV-9A
05-08
2326
Jim Novak
RV-8
04-30
3660
JAMES TRAYNOR
VELOCITY- XLRG
04-25
2625
Charles Wright
RV-8
04-21
84
Robert Lussow
RV-10
04-13
2834
Robert Lussow
RV-15
04-13
Robert Lussow
RV-15
04-12
Brian Robinson
Xenos
03-20
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
03-11
2234
Joe Loxterkamp
https://eaabuilderslog.org/
02-12
James Chadwick
RV-7
02-01
1013
Mark Spedding
COZY MK IV
01-14
3925
Randy Doughty
CH750 Cruzer
01-10
1001
Stephen Satava
RV-7
12-30
2967
Chuck Bennett
Sonex-B Tri-Gear
12-28
1399
Andrey Piskarev
Highlander
12-27
4497
Richard Tice
RV 7
12-09
987
Doug Volkmer
RV-7
11-24
1250
Stephen Eastham
CH-601 HDS
11-17
564
Robert Chopin
RV-8
11-15
868
Mark Weitkamp
CX4
11-09
3047
Projects Uploaded: 1564
Logs Uploaded: 288554
Copyright © 2001-2026 Matronics. All Rights Reserved. Privacy Policy.
