Previous Builder
Next Builder
Date: 05-18-2013
Number of Hours: 3.00
Short Description: Stick grip
Installed the new stick grip. I cut the stick down about 2" and slid the grip on. I then solded the PTT to the wire I had already run into the stick. I had previously run wiring for the pitch trim but not the roll trim. I had to run that wire and solder it all to the grip top. I have changed my mind on the autopilot servos I will be using. The G3X servos allow for the trim to be controled through the servo. This required a exra set of wires into the wing and a loop in the run to the pitch trim thqt will be later cut and connected to the servo.
Ray Allen G205 Stick grip
ACS 510-2 start switch
Previous Builder
Next Builder
