The maojority of today was spent speking with vendors on the leaking brakes, as well as the glareshield cover.
I needed to take several photos of the cover and template as well as remove the cover. It will be returned and modifications will be incorporated in the new one.
The new master cylinder is on the way, the leaking one will be removed and sent back tomorrow.
I did power up the avionics again today. This time using a 20 amp power supply...it worked much better. Most errors went away when I attached the right wing roll servo. This completed the network connections. I do have two additional messages. One was the AHARS has not been calibrated; the other was a GMC507 overcurrent. I believe the circuit breaker value on the GMC507 circuit needs to be increased. The AHARS error will be corrected at the airport.
